Well after 15 years of use I managed to do it…my puck appears not to have been properly seated and disappeared into the player.
I’ve turned it off and thought before monkeying around I should obtain some guidance. How does one best retrieve a puck?
Okay thanks.
Took player out of rack and did gentle tipping and voila!
All’s well… plus did some much needed dusting…
IJHB
December 12, 2019, 2:37pm
#4
It’s pretty easy to pop the top off of the CD5 to retrieve a puck.
You do need to be careful though with the lid. You need the correct tool and when fastening, it’s easy to go a tiny bit too far and dimple the zinc magnesium case.
system
closed
February 10, 2020, 3:03pm
#6
