Naim CD5X
II have the above cd player, a while back I put a disc in, the disc spins but no sound came out, Naim said that without looking at it the Dacs had probably gone in it. Would it be worth selling or just bin it?
Did you check that you’ve chosen the correct output? They can sometimes change from Din to RCA by themselves.
Its a great player, I’d try a few other options before giving up.
If Naim won’t touch it, try alternative technicians, there might be people out there willing to help, I’m sure.
I have great memories of this player myself, with a FC2X psu.
I did.
Lovely sounding player, in many ways a junior CDS3, really worth trying to keep on the road.
A long time ago, back in 2017, I had exactly the same problem. Naim repaired it with the help of their French distributor, and the cost was quite reasonable. I can’t remember the exact amount, but it was pretty cheap.
The technician told me he had replaced an operational amplifier (op-amp) and the DAC.
This CD player is fantastic, especially when powered by a Flatcap 2x, which makes a noticeable improvement to its sound quality.
You’ll never find a rubbish bin worthy of it!
I have spoken to Nam and another tech company and neither will fix it as they cannot get the Dacs.
Have you looked at the little platter that the disc sits on. They are prone to split and not grip the shaft properly. Can be fixed with a drop of superglue gel.
