I loved my CDS, nice memories even its many years back.
Today, no players that I know of, comes close to what CDS did.
Not sure this is a good idea. Apart from the Brand (Naim) it has nothing in common with a CDS, apart from I guess its still being serviced and supported?. It is discontinued by now.
Buying new CD players today, I’d make sure to buy into a Brand which will support you in future.
I ditched Naim CD players due to the end of mech service/support, went to Rega, they still service their older players, and sound is great. Their Saturn players are much better than Naim entry level CD5i range - I know as I’ve owned both.
A well-sorted CDS1 playing well-mastered CD sounds like a good old pre-cirkus LP12 – not quite there yet performance-wise, but the experience is similar. As PerF said if that’s what you are into CDS1 is the one to go.
Having owned the CDS, CDS2, CDS3 and had home trials of the CDX, CDX2 and CD555 (in addition to the Linn CD12), I can say that in a fully functional form, the original CDS is the preferred player.
BUT….this requires a custom Black Burndy to the CDSPS as the original gray one was far too colored.
Ironically even with the Black Burndy the CDS is more colored than any of the other players, which although subjectively more rectilinear were also more musically sterile.
I think this is largely due to the choice of DAC chip in the CDS…the double Crown version of the TD1541 and to a lesser extent the robust CDM Phillips transport and the CDSPS.
When I had my failing CDS upgraded to the CDS2 (a short term upgrade offered by Naim, which kept the outer sleeve of the CDS, but replaced the entire electronics on the inner sled with those of the CDS2), I had the ability to use both the original XPS and the CDSPS. Although the failing CDS transport sounded dire, before it failed the CDS I believed was quite superior to the CDS2 in terms of sheer musical enjoyment, as its colorations were quite palatable.
And the CDSPS was preferable, and stayed that way until the XPS gave way to the superior XPS2. This I think mirrors the 52, the original 52PS sounded more enjoyable to the Supercap.
Both the 52PS and CDSPS I believe used dual transformers, which were relegated to a single one with the Supercap and XPS. But dual transformers did not pass electrical code for several countries, so they had to be replaced by a single one. I may be mistaken on this…but also I may not.
You’ve had a very similar experience to mine. I’ve used the CDS for a really long time, having owned models from the early, middle, and late serial number runs. My friend owns both the CDS2 and CDS3, so I’ve listened to them frequently on his Naim system. Last year, I briefly tried out the CD555, but it didn’t stay long and was sent off to a second-hand shop soon after.
In my experience with the CDS over the years, the early serial number models sounded the absolute best. When I opened up the CDS mainboard to recap it, I noticed a Philips TDA1541A S1 chip with a single crown mark—and right next to it, it looked as though a second crown had been erased during the manufacturing process. On the other hand, the late-production CDS units used Taiwan-made DAC chips, which had a harder, stiffer sound compared to the early units. To keep mine running for a long time, I’ve kept a spare Philips 1541 Double Crown chip and a CDM4 laser mechanism on hand.
Also my experience when I owned a CDS2, I much preferred the CDPS/Black Burndy over the XPS, to my lugs more musical, kept the CDS2/CDPS for a fair few years.
Ron, your experience shared in the old forum was my guideline as I was shopping for CDS1/CDS2 and 52PS/SC, and everything just turned out as you said.
I listen a lot to vintage albums CDS’s colouration is actually going well with the older CDs. The black burndy is good, but I feel like if the grey burndy sounds more ‘period-correct’ and sync better with the sound of TDA1541.
I have one. It’s the CDS-1 with the nice metal remote (later production??). I bought it used and have it for 20 years. It’s still going strong and sounds magical.
I recall many years ago when I bought my CDS3, having heard reports of mechnisms failing, I was concerned so spoke to Naim on the 'phone. When I asked how long it was likely to last from new I was told it could be anything from 2 weeks or 20 years or more!
The relative humidity in your area plays a role as well. Electronics tend to last a lot longer in drier climate than in an area with high ambient humidity.
The saddest audiophile day of my life was when my CDI finally failed for good. After decades of hard daily use. Was very close to the CDS in sound quality. My current rig has the advantages of the convenient Naim app, ability to play high res files, and great overall sound quality. But while that quality is better from a checklist point of view it is unclear to me that musically the CDI or CDS could be beaten for pure musicality on cds.
The nice metal remote is actaully earlier production. Early NAC 52 preamps also came with a similar nice metal remote. The nice metal remote that came with my 1991 NAC 52 preamp became a paperweight after I had the preamp updated to then-current spec in 1999 as the remote wasn’t RC5-compliant.
By far my favorite of all the many Naim remotes over the years. Mine became redundant when the CDS gave way to the CDS2, and I ended up giving it away to someone who needed one.
My least favorite was the ‘Thors Hammer’ remote (aka the Flash).
I also ended up giving that one away.
