bruss
#1
I’m starting to box up some kit and don’t know which inter connects I should be including in which box as per original Naim supplied.
Power supply (Hicap etc)
Pre amp ( 82 etc)
Power amp (250 etc)
Olive, CB and Classic if it makes any difference. Any help appreciated.
Here you go…
https://forums.naimaudio.com/topic.php?oid=1566878604301792&coid=159503632588890
Re. the Hicap, the original SNAIC5 may well be a grey one unless a very late Olive example.
system
closed
#4
