The most recent Steve Hackett live CD from The Albert Hall is not looking up on MusicBrainz when I am certain it exists on that database.
Probably there is a discrepancy somewhere in the lookup references, but I have no idea how to fix this.
None of the lookups are fetching recent releases. There isn’t a known bug but Naim is looking at it.
I now suspect it was a DNS issue. I found out after the new firmware update and after entering google all 8s it now finds the Hackett album. When this happened I don’t know, but I suspect it was at least something to do with today’s update as the symptoms had changed a little.
In recent weeks the check for firmware updates worked in that it returned the current level and said there was nothing new. Today after the update I searched again and it waited ages and then returned a zero. Happened 3 times on the trot and that’s what led me to check the DNS setting, which had been entirely knocked out to blank fields.
DNS on which local device?
ATB, J
Core network settings
Thx
Mine appears correct but only as set by DHCP…… Won’t let me manually set a secondary (service provider) DNS.
ATB, J
I had mine set up as a static IP address.
