Hi , i,ve got a Dac , with both sync and HD lights flashing constantly together , is this significant ?? I,ve never seen this before , does anyone here have any ideas … thanks …Roy
Just to check the obvious first. Do you have the link plug inserted properly. From the manual -
Note: If the DAC power supply link plug or external power supply is incorrectly installed the hd and sync indicators will flash.
Aaaahhhh , good spot that man , thank you … forgot all about that … total brain fade … i knew someone here would know … i,ll get me coat … thanks Roy
