To save you time, the manual doesn’t mention it. If it were me, I’d turn on the 555 first, for exactly the reason mentioned by Nathan. But given that suzywong does it the other way and lives to tell the tale, it clearly doesn’t matter.
The whole reason for the power amp on last and off first is to stop bangs over the speakers, so how you turn on sources is far less of an issue.
When the PSU upgrade option is used with the Naim DAC, power supply separation is further increased by the use of a dedicated supply for the master clock circuits. It also provides a bigger toroidal transformer and bigger reservoir capacitors, and the DSP remains powered from the Naim DAC transformer to give even more separation from the analogue section
Good info, I hadn’t thought to look at the white paper. I don’t know whether the nDAC uses the WM8804 IC, but that particular chip prefers the back half powered up before the front half receives the bitstream; in practice though, the chip powers up and stabilises long before the upstream processor finishes booting and activates the bitstream.
From a previous life, I recall that we turn spacecraft on “front to back” so that the each stage’s signal stabilises before the next stage goes live. It also avoids floating inputs to a stage.
The nDAC goes into a start up routine when you switch it on, and various lights flash on the front panel as it looks for a source and identifies whether the signal is hidef or not.
If you switch on the psu before this process has begun, does it start the analog sections of the nDAC before the nDAC control circuits are on?
If the XPS powers only the analogue circuits, then there will be no “boot up” time like with a digital circuit. For sure there is an “inrush time” when the input caps all charge up, but this is the order of a couple of tens of milliseconds max - we always get our suppliers to measure it; I had a case many years ago where the suppliers pSpice analysis of a particular unit reckoned 0.5 Amps inrush current - the reality was 6 Amps, and I was attempting to power up six at a time…needless to say, the Central PSU tripped out every time…… oops!
I “forgave” the circuit designer coz he was a staunch Nightwish fan!
