Hi All
I am thinking about getting a NAIM DAC V1 for my office to upgrade my CD player.
I also listen to internet radio on my phone. My question: is it possible to connect my Android phone via USB to the NAIM DAC V1?
Thanks in advance!
Chris
Hi All
Thanks in advance!
Chris
The short answer is no. If you have a computer in your office can you connect it to the V1? This is where its USB input really shines, so if you can get iRadio working on your computer the V1 would be a good choice.
While not an android phone, an iPhone did work fine while connected to a V1 via USB (with the usb-adapter from the camera connection kit).
