Hello everybody
I posted already and got some useful feedback about activating my passive DBLs. What seems to be clear is that the amplifiers should be the same type, or at least from the same manufacturer/ character.
When using different amps, the ones with the best quality have to drive midrange/ tweeter.
So the most safe and for sure a premium quality way is using the speaker with NAIM amplifiers.
But I made some really nice experiences with tubes, indeed with none NAIM speaker.
So does someone made experiences with NAIM speakers (DBL or similar) and are there any (technical) nogoes to run a DBL with a good trio of “suitable” tube amps … I know it’ll sound a little cracy for some ears but so far it’s only a question.
Thanks in advance and
kind regards
Jo
