Did you use gasket or silicone? Did you experiment so see which is better sounding, my bet is on silicone :).
The silicon , other than providing the air tight seal, also serves to hold the woofer in place. As mentioned by Geko, when you play loud, the bolts will slowly loose their torque.
Hi , does anyone know who is the designer of the DBL ? After spending 25 years with it, itās really hard to find a replacement. I bought a ATC150 last year and sold it within a few months. Costs aside, it just doesnāt have the same level of musicality and excitement of the DBLs.
Roy George it was.
I agree,I havenāt found any speaker thatās better when it comes to musicality and involvement.
I also agree. Two friends have Ovator 800ās, which can compete, and in some instances, offer a more balanced sound across a broader range of music. However, get DBLās on a good systems playing live jazz or rock and roll and thereās nothing Iāve heard that comes close!
Iāve never heard a system or a speaker that comes close to my 3x500 DBLs.
More hi-fi yes, more music? Nope.
Sounds like it would make sense to use threadlock on the bolts, enabling use of a gasket that doesnāt cause difficulty with removal at a later date.
As IB suggested thread lock will work but donāt go mad with it just in case you need to remove the screws/bolts at a later date, screw lock might be better as itās not so aggressive and helps if itās just vibration thatās causing the fasteners to work loose over time.
Loctite have variable threadlock products from permanent, to requiring a head gun to head the bolt and soften the threadlock to the weakest one, which I use though on binding posts, not drive bolts, which just requires a tad extra force to get moving and is actually for preventing vibrational loosening.
You donāt need threadlock on drive unit bolts. Just done up to the required torque is all thatās needed. Itās a loudspeaker, not a motorbike.
