Naim DIN to ATC active XLR - speaker cables
Seeking a basic cable solution for connecting Naim SuperCap DIN output to ATC active XLR speaker input.
To be clear, I am not looking for my “end game” cable. Just something that will get me solidly connected while budget recovers from the actual speaker purchase.
Easy / speedy order fulfillment in the USA is a bonus.
I have purchased all my gear second hand, so I don’t have a close working relationship with a dealer.
I had two cables built using Mogami 2549. Din at supercap and XLR at speaker. Seems to be a good starting place
Thanks for the response. Who built them? What length are you using?
My local dealer built them in the UK. I believe the spec for the cable is in the ATC speaker manual. Mine are 3m in length. If in doubt just drop ATC a line
I recently purchased these very cables from well established uk seller on ebay, they were easily located using the search mogami 2549 xlr, I’m using 3 metre long versions and they seem very good quality for the relatively small outlay
