As a subscriber to the Naim mailing list I got one today with a playlist called Looking Back to 2018 along with links to listen to it on Tidal or Spotify. I have a Sonos Connect with a Tidal subscription as one of the services, how can I listen to the playlist using the Sonos? Is it even possible without entering it all manually?
Assuming the Sonos interface will work like the Naim app, you have to go click the link on you pc or tablet to take you to Tidal, then make the playlist a favourite. This should make it available through the sonos app like it does for Naim
Finally got round to trying this and it worked a treat, thanks for the help
