What can it be used for / on?
Would one work with my 252 and/or NDS?
I use mine with a 252 and CDS3. Not sure about a streamer though.
Should do. It works with my 552 and CD555, no problem. If you have just acquired this handsome piece of remote control look after it, i.e. try not to drop it, Naim can no longer service it so if its breaks that’s it. The screen on mine went haywire. It would sort of work but not very well. I managed to get a new boxed one at a bargain price so just got lucky.
Douglas.
The Flash can be used as a substitute for a Narcom remote - so for controlling a suitable pre-amp, integrated amp, CD player, and tuner. On the last units (and units that had the relevant PIC chip upgrade) you could switch screen tabs to AV and also control an AV2 or n-Vi, DVD5 and n-Sub.
Mine does not work on NDS
