Naim flatcap
Hi all managed too fix the Systemdek new parts have been installed work fabulously. I have just purchased a olive flat cap but don’t know where to plug it into the preamp. Do I need to pull out the Naim plastic plug on the preamp and plug it in there.
Tosh
Broadly yes.
But… I recommend you read the manuals - which are on the Naim website… :slightly_smiling_face:
Here’s the connection guide from the manual;
So I have the flat cap and the power amp I’m confused how they connect to the pre amp can someone guide me please
Just follow the diagram that Richard posted. That shows the 92 connected to the Flatcap. Connect the power amp to the 2nd socket from the right on the Flatcap.
Will do thanks everyone….
