Can anyone shed some light please.
If I go into my preferences, it is saying, since May 25th, that my " recently used devices" are in a town in Scotland.
They are not.
I have reset my password, no difference.
Is there something sinister going on that I should be worried about?
Any thoughts would be welcome please.
Update. I have just looked at the same thing on another Forum that I frequent. On there I come up as Woking, Surrey. Miles away again.
However the login times does suggest it is me and not someone else
That information is not visible to other forum users, so at least not giving out that information - false or not. Presumably the info is available to Discourse administrators, though whether that includes Naim I donāt know. But from a personal security point of view, the information being incorrect is probably a good thing!
Itās not very accurate, so I wouldnāt be too concerned by it, and similarly it thinks my devices are being used in Scotland too, so doubtless an ISP thing.
I suspect its more to do with your ISP, router, hub or similar rather than the Naim app.
Mine has never shown an error that Iāve noticed with both the devices I use - āWindows Computerā or āiPadā - and opening up āShow (number)ā it shows all listed correctly going back to 10 May.
And if its relevant my ISP is BT & Iām on BT SmartHub-2
Iām guessing it depends on which optimal server your internet provider happens to be using at any given time, which will vary from time to time.
Right now, TalkTalk are using a server based in Stockton-on-Tees, in County Durham, whilst Iām actually North East of York ā¦ the Forum, however, has me in Bridlington, on the coast.
