Hi,
I’m sure there has been a thread before but cannot find via a search. Want to dismantle my Fraim, give her a good clean and reassemble. Does anyone have good instructions to do this ie. torque settings etc.
Gordon
Thanks Dave
One minor bit of advise having done this a fair few times, is to use a good quality spanner to do the tightening of nuts rather than using the one that Naim supply in the box which is ok if you don’t have anything to hand but not the best.
It’s worth taking the shelves off a few times a year and just tightening the legs off as they do loosen off a bit over time.
I’ve always just done them hand tight and about as far as you can go.
