I have searched Google, YouTube and our Community forum, with zero results.
I have sold one of my Fraim Levels and need to repack it.
For the life of me, I can’t remember how it was packed inside the original box.
The glass shelf is self explanatory, but I’m scratching my head on the wooden shelf, the metal supports, rods and stainless steel bits.
Please could anyone assist with repacking advice, or have got any photos?
I don’t want to pack it any old how and end up scratching the components.
The Wooden shelf goes in the box on the left, which then goes on top inside the box on the right. You should have some end sleeves to fit over the Fraim Glass, I can’t see them in the picture though. That goes underneath the top box. The legs go into each end of the long box sections, and the final box section takes the bag with all the metal bits - spikes, nuts etc…
Thanks Richard👍
The glass corner protectors are not in this box, but maybe in one of the other five boxes in the loft, which I’ll have to retrieve.
I actually thought the glass went in to box on the left as it has protective wrapping.
Apart from corner protectors, does the glass have any other covering? No an issue if not, as I have plenty of bubble wrap.
Hi Richard
Yes, I agree. Just checked all the other boxes. Only one Tommy Bar, Spanner and Instruction manual, which would have been in the Base Level box.
I guess if you think logically, you can’t really have a Fraim system without the Base shelf?
Anyway, all neatly packed away now. Thanks for your help.
