Hi I’ve just got a pair of name IBL Speakers back from a friend. I left them with him and they’ve been in a dry loft. I forgot all about them for over 8 years
One of the tweets has been pushed in so I’m just wondering if there’s a replacement model that I can get that will fit in with the crossover. I was wondering if good quality ribbon Twitter could be used as a replacement. Need something that’s gonna be compatible with the crossover on the back of the speaker..
Does the tweeter still work?
Vacuum hose should work, suck it back out?
Some friend!
Hope you can get the tweeter sorted out.
