Quick question, do any of the Naim remotes e.g. Naim R-Com reference offer an IR learning facility to control other brands products?
No.
Thanks HH
Note that Naim use Philips RC5 codes, and there are standard code sets used by a number of brands like Philips, Marantz, Arcam, Meridian etc… This means that if you use say, a Meridian CD player with your Naim system then your Naim Narcom, Flash or R-Com remote will operate most of the main functions of the Meridian. The R-Com even gives you an open/close button…
