I’m updating my Internet Radio presets on my NDX2 and can no longer find “Naim Jazz”, Naim Classical" or “Naim Radio” (I searched the forum and couldn’t find anything).
Did Naim discontinue these services with the switchove from vTuner to Naim Internet Radio?
Thanks Robert. I did search through all those folders (and just looked at the “Brands” folder again) but no Naim brand in there. I have an NDX2 but I don’t think that would make any difference. I just updated the app to v7.3 - maybe there’s a glitch in that?
I use a third party control point app in which I have to enter urls. If these urls are of any use here, try this:
Try International, Europe, United Kingdom, Brands, Naim. The channels should also be in the Hidef category.
That did it. Thanks!!!
Hello all !
ND5XS 4.9 and app 7.4 from yesterday.
Perfect !
One remark :
My humble opinion is that finding a radio is really tricky.
You first have to know the country of the radio and then choose browse all to find …
If you don’t know the country, almost impossible to find …
I would prefer enter a radio by the name in the first search bar … Much more convenient !
You know a radio for its name, not its country …
Please, Naim, take into account
Bertrand Dubois
Hi @sktn77a
As you have an ndx2 use the search feature on the top right of the app.
So enter the search term and expand the radio results section. Example:
Best
Steve
I updated my naim ndx (2012) to version 4.09. I have a question, is it possible to search for radio stations in this version of ndx by typing in the search field?
