Naim K Boards or a Primare R32
Please help,
I have an opportunity to obtain a Primare R32 Phono Stage, but will it be better than my K boards.
I have a Linn LP12 with a AT OC9 XML cartridge.
I like the sound of the K boards, but am thinking that an external Phono stage might be better. My pre-amp is a nac 82 with two hi-caps & nap 250.
Thanks in advance
I think that the K boards might be better than a Primare.I would suggest trying a Naim Prefix ,they can found for not so much money these days.
I used a Stageline-K (basically K boards in a box) with Linn and Lyra cartridges for many years. It’s a good phono stage providing it matches your cartridge, electronically.
I’d probably go for the Primare, though, if presented with the choice of either.
