Naim lavender din interconnect, which end to source?
I just bought a used Naim din lavender. Which side does the tag go on? Source or preamp?
Many thanks!
Band on cable at source end.
With naim you just do the opposite way of normal and it will be correct :smile:
Thank you!
Or what ‘sounds better’.
I recieved the lavender cable today. It is long and touches the ground. Is there something to be gained if I put a loop in it so it hangs freely? Is putting a loop in it alright?
I would loop it in preference to having it touch the floor. Ideally you want it to hang clear of anything else too - other cables, shelves, walls. Especially power cables.
Assuming that it makes any difference at all.
Thank you Chris.
