Does anyone have a summary or pictorial of the new and old classic range, in terms of what the components are and do, what can be used with what or not?
I keep finding the new 200, and 300 ranges confusing and prefer a “this unit, needs a pre or power, source and can work with and upgrade to …”
It would take ages to answer that fully, and most of the answer would doubtless be irrelevant. Maybe you could hone the question into something a bit more specific. Would knowing that a NAC32.5 can take the benefit of a dual rail supply whereas a 32 cannot really help?
Ok some more meat or essentially what i want, but a number of ?s
So after a sell up of a top end Naim fully loaded active olive setup, 10 odd year haitus, i spotted a Muso nabbed it, then Atom for a week and then the Nova which has SURPRISINGLY remained since its launch.
Maybe demos of NDX2/SN3 and beyond, not convinced VFM or worth a marginal improvement, new Classis ranges drops and i get confused as to my options.
Surely the best thing to do now is find a Naim dealer who can find out what you are after and advise you?
This is what they do and are generally very good at it.
Could but i prefer to research, narrow down and have a plan, then demo.
Many moons ago i used Lintone and Rayleigh Audio, but they are no more and option, the current toe tapping dealers i don’t like, except to demo and buy.
I wouldn’t worry I knew nothing to start with (glad I started with an atom honestly I didn’t even understand cables when I first started looking at different hifi options ). You’ll soon understand it, I still don’t know all the numbers for older pre old classic kit.
