Naim Mu-so 2 & Google Gemini support
Just wanted to know because i see quite some problems of Gemini support with the Naim Mu-so 2 …
Op top of that, will the Naim Mu-so 2 support Google Gemini?
I’ve struggled with using Google Home and the Google Assistant with Naim streamers. You can search this forum for threads which I started or in which I participated. (I ended up switching to Alexa, which has been more reliable to date.)
Not sure what you expect Gemini to do in connection with Naim products.
