Wanted to share a trick I found that helped open the remote for the Naim Mu-So 2nd generation.
It was impossible to open the battery compartment at first with sheer force, but I figured out a workaround.
I used a thin, credit card-style piece of plastic (little thinner than standard card, like an insurance card), and shimmied it into the seam, and it gently opened after a few times back and forth.
It didn’t damage the case, and now the battery compartment opens with ease.
This style of trick has been mentioned a few times, and i can look forward to usung it when my battery requires changing.
What would be even better, is not having to use any tricks at all.
The worst remote I have as far as changing batteries goes, is that for the Amazon Firestick. I usually have to go into the garage to get a vinyl glove (useful for when I get round to painting the woodwork here). That’s the only way I can seem to get enough traction on the d*mned thing to push it off. Why doesn’t it have any ridges on it to give better traction. (sigh)
Nice, I hadn’t seen this exact solution mentioned, so figured I’d share. Not sure if it was just a first time opening issue, but it works as expected and slides right open now.
Having read comments previously, I had wrongly thought “surely it’s not so hard“?
However, having just tried to open my own remote, it was impossible! Sliding a piece of plastic around the edges did indeed get it moving and I can now change my battery
Thank you.
However, having changed the battery, mine is still virtually impossible to open again, so I will have to resort to the thin piece of plastic trick next time it needs changing!
