Really enjoying the sound from my Muso 2 but Ive noticed recently that the light on the side is flashing purple. The unit is connected to wired network and seems to be working ok but the light is quite annoying. The manual says the light means the unit is in wifi setup but this isnt the case. Am I missing something
It sounds like it has somehow got into WiFi setup mode. Have you tried disconnecting from the mains supply, waiting for say half a minute, and then turning it on again?
