Naim Muso 2nd generation 3.5 mm jack issues
Hi all. I had a problem with my Naim Muso 2nd generation 3.5mm jack.
I connected my Naim Muso 2nd generation with Mac mini M2 by 3.5 mm jack. I changed Naim Muso 2nd generation input source to “analogue” and change my Mac Mini output to headphone. But i heard no sound at all. I tried to hard reset my Naim Muso 2nd generation but it’s still not working.
Does anyone have a solution to this problem?
Can you hear anything if you plug headphones into the mac?
I solved the problem.
My 3.5 mm jack is headset. It’s mean you can use the microphone. I change another jack. Thanks for your help.
