Hi,
tonight my Naim MuSo was nit reachable anymore from the app.
I tried to turn it off, turn it on, reset via the pin hole. nothing changes. I even restarted my iPad.
In the app my Muso appears for some seconds (but I can’t select it) and then it disappears again.
It is connected via Ethernet.
What else can I try?
Tonight I will leave it disconnected from the power line.
Try turning off the muso and your router. Wait a few minutes then turn the router on. Let it boot up, and when it’s ready turn on your muso. See if that works.
Yes, I would try power cycling your router and any switch you may have. Also power cycle the Mu-So with a full power down (plug out - wait 5 minutes - then plug back in).
Hi, and thanks for the answers.
At the end it was a power line adapter that was somehow stuck. It was losing and delaying packets.
After having pulled it off and put it back in everything worked as expected.
