Naim Muso QB 2, updates, how often?
Frequently two or three times a week (maybe more) I have to unplug my Muso QB 2 and the dial does a it’s revolving display before I can use it. I’m guessing this is it updating?
Is this correct?
Is there anything that could be causing this other than very frequent updates?
It is really annoying me!
Simon
It’s not updating. Updates happen maybe once or twice a year. It sounds more like it’s losing contact with your router. If it’s using wifi, try wiring it or boosting the wifi signal using access points or whatever.
Ah OK, thanks for the reply. I’ll try a ethernet cable.
Diolch
Simon
Same happens with ethernet in my experience…
