NAIM Nac 202 Issues
Have had my Nac 202 for quite a few years it has a NASPC and a Flat cap attached it is connected to a Nap 200
What I have noticed recently is that the buttons on the front ones to switch between sources and the mute button cease working when manually pressed. They work fine when I use the remote however. What I don’t understand is what the problem is it comes and goes.
Has anyone had similar issues with a 202?
im guessing the buttons have some crud around/ underneath so they get stuck? maybe squirt some contact cleaner on the button or something else that will dissolve finger grease etc.
Get it serviced; I would not squirt switch cleaner into any Naim product. There are better alternatives.
Why not? That’s its intended use?
Hi,
It could also be a connection issue between the boards. Do the indicator lights go out? Has the NAC been moved or transported recently, possibly exposing it to significant vibrations or shocks?
I would also be cautious about using spray products, as they contain solvents that could damage the finish of the knobs, and I think it would be better to have it checked by Naim.
This preamp/power amp combination benefits greatly from being powered by a HiCap.
Best
Lionel
