Hi:)
Naim NAC 202 - sockets with in and out signals (hdd in/ out, av in/out).
Is it possible to turn the outputs on and off? How?
BR,
Andres Toom
If you mean, can you mute them, then yes you can. It’s in the owners manual as follows;
13.2 record mute
In order to minimise power consumption and improve sound quality the NAC 202 record output circuit can be muted. To engage or disengage record mute press the front panel mon button followed by the front panel mute button. The mute button indicator will illuminate when record mute is engaged and extinguish when it is disengaged. Record mute can also be engaged and disengaged from the remote handset using the mon and mute keys.
