Naim NAC-N 272 display blinking and stuck on input initialising
I have a partly similar issue to ‘272 display blinking’. except the NAC-N had been is use. Was just shut down to connect a CD player, previously OK.
I have tried shutting down for 30 seconds and restarting the router. no change I have not reset, perhaps I should?
Rich
I have now attempted to start with Stop being pressed and held for around 30 seconds. It appeared to have no affect. no reset menu appeared. It seems a bit weird as nothing detrimental had really occurred and I have now removed the CD player. but still turn it on and it blinks with the logo and it reaches Inputs are initialising and never completes that stage. I say never it has been on and doing that for over 5 minutes. no change.
I have now got further and into reset all settings. Clearing networks is taking a long time 2- 3 minutes and counting. The display and logo continue to flash, but maybe that is normal for reset.
it was stuck on Clearing networks for over 1hr.
I figured it might be an idea to turn it on, with no connections except power. That produced a new error BridgeCo boot fail” (fault 28)
So I reconnected and then it said 2PSUs unplug and try again in 10 minutes. Tried 3 times and now with Naim support on phone. and the BridgeCo boot fault is a possible fix with Naim. and now in discussion with the dealer.
I have a Uniti 2 which also got the Bridgeco fault. It has also had some problems with the power switch and CD-player so I found out it was time to retire it. I tried all kinds of resets, and also tried to have it turned of for a while, nothing helped.
I bought a used NAC N272 and NAP 200, which was probably not so smart since it is the same generation, but they work fine. After I had installed 272/200 I tried to power up the Uniti 2 a last time, and suddenly it works again! Now I have it connected as a cd-player, I have no idea how long it will last this time.
In this case, I suspect that the unit has a hardware fault in one of the power supplies & the resulting error states are a result of that fault.
This can be proven by testing if the 272 works without issue using an external PSU (e.g. XPS).
If so - we can fix it.
Neil.
Thanks to both. prior to the failure, I was about to purchase a PSU XPS 2 but that idea was aborted as I figured that might work. but Naim staff (Duncan) said the error indicated that the streaming module was at fault. and that it might be fixable, but that also that there are no parts available. On speaking to the Naim dealer. he and I agreed it was not worth spending £400 knowing the fix might fail, due to lack of parts. I found last times I tried to power it up, with nothing expect power connected.
I have not tried without the link plug, might that be wise during test to get running?
Unit seems to think there are 2 PSU’s when in fact there is only the onboard one.
At the moment, I am planning on purchase of a NSC 222 this is planned for tomorrow. but would happily put it off. if there is a chance of recovery, after all.
So far as I know I have no means to check an external PSU connected might make the difference?
Richard
The unit will not work at all without the link plug.
Duncan is correct regarding the lack of parts to fix an issue with the streaming module, however, all the symptoms would suggest to me that the internal power supply is at fault.
The flashing display indicates that a brown-out is being detected on the AC input, the 2 power supply & BridgeCo errors can also be caused by missing supply rails.
Testing with an XPS will effectively render the internal AC part of the unit (the part I suspect) redundant & therefore prove the theory.
Maybe your dealer has an XPS or 555PS you could test it with?
Neil.
thanks for this Neil. Very interesting.
My local Naim dealer in Epsom has no PSUs. Does anyone know of any dealers somewhere near Surrey. likely to have an XPS or 555PS available for a test please?
Richard
