Naim Nait 2
Will probably use 5m naca5 from main set up once I have replaced it. So hairdryer and S folding next fun project
Folding cable tip …
If you use cable ties, be careful not to over tighten as they will nip, permanently mark or even cut into the softer insulation of the cable.
Consider Velcro tape, I use 2cm wide, available from the usual www vendors
Or, indeed, packs of velcro cable ties (which is what I use on my cables) No cutting required.
Excellent advice. Thank you
How could I forget. Linn K20. Very flexible and more importantly very cheap. Btw I think Nait for desktop is a great setup. What’s your DAC?
Epiphany Acoustics e DAC very simple very neutral
Sourced some new 4m naim factory NACA 5. Must say very well finished. Now on main system in very tidy non coiled fashion (well open gentle loops as arrived tightly coiled) and sounding good. I will see if that improves. Now to figure 8 2x5m NACA 5 for desktop. They are sitting behind warm radiators in prep.
Well the sound on the desktop system has transformed. No idea why I ended up using QED. I suspect it was simply not thinking as PC setup. Bass has appeared. Warmth has appeared. I would post pics of my beautiful figure of 8s but I am not spending any more time under the desk :grinning_face:
