This might seem like a noob question to some: I have a Naim Nait 3 with integrated phono pre-amp that I use with my turntable… I am looking at buying a pair of 6 ohm rated speakers - will these run fine or will they cause any issues for the amp?
If I am not mistaken the Nait 3 is rated for 8 ohm.
From what I’ve been able to gather, generally it’s fine to mix 6 and 8 ohm rated equipment, but I was wondering if anyone has specific experience on this topic for the Nait 3, or. if anyone has any general advice. Thanks.
You should be fine with a pair of 6 ohm rated speakers. Naim amps are generally ok with impedances down to around 2 ohms and a 6 ohm rated pair of speakers will likely not dip below 2 ohms unless highly reactive. Out of interest, which speakers are they?
Dali speakers are not known to be hard loads and there are Naim users with Dali on the forum.
FWIW I run a UnitiQute 2 with 6 Ohm speakers and I am sure lots of users even use 4 Ohm speakers with Naim (Dynaudio are often 4 Ohm). If the amp is will within the power rating of the speakers, you should be fine.
We used a SuperUniti for a while with 4 ohm Sonus Faber loudspeakers. No issues really although bass was a bit flabby. Added a 250DR which was transformative.
If a 2012 amp can drive those I’d think a Nait would do just fine with 6 ohm speakers with higher sensitivity!
