I bought a Naim Nait XS3 three months ago and though I am very happy with it, something is just bothering the he-- out of me.
What should be my “Streamer” button says HDD and
What should be my “Phono” button says AUX1.
If you were going to change anything you surely would have changed the Tuner or CD buttons first I would think?
Is anyone aware was a design change made to the front panel buttons of this unit?
I have the serial number on the box showing it’s an XS3. I haven’t pulled it out from the wall to look at the back however I have a turntable hooked up to the phono amp I do not believe the XS2 has a phono amp? My dealer says they must have done a revision on what they are labelling the buttons for todays’ listeners? That sounds logical but after having worked in the automotive industry for 20 years and know guys on the line will pull any part that works when they are short parts I am cynical. Also, if you were going to kill certain button names you would surely kill the “Tuner” button and make it an AUX button before the Turntable. HDD in place of Streamer is more believable but still does not make much sense to me?
I have sent my inquiry to Naim product support. I know this is a minor issue but I still see the unit advertised with the more common buttons and it just irritates me.
I would suspect that some XS2 button strips have somehow accidentally got mixed in with the XS3 ones. I would contact your dealer as I’ve made Naim aware and I’m sure they will want to rectify the situation ASAP for you.
