My friend has just bought a Naim NAP 150, last serviced in 2015. This has a spec of 50w into 8ohms.
His speakers are Mordant Short MS 914 which requires an amp capable of 15-150w into 4ohms.
Question is, would the 150 drive these OK?
Yes, no problem at all using the NAP150 with those.
Nap 150 should be fine as the speakers are fairly sensitive.
Divide the model number of a Naim power amp by two and you have the RMS power per channel into 4Ω, roughly speaking.
