Hi
Could anyone tell me if the Nap 180 amplifier would be ok to use with Quad 57s I believe Nap 250 and Nait 1 integrated amps are often recommended but cannot find any other amps from Naim that are recommended.
Thanks in advance
Hi
Thanks in advance
The main issue is current. So with an amp like a 250 you needed to be careful not to drive the ESLs too hard. The NAP250 could be factory modified to limit current for use with ESLs - what Naim used to call a Quad-mod.
Using a NAP180 iwith ESLs is probably OK - I used a NAP110 with mine - but just watch that you don’t push them too hard.
Thanks for reply I’ll give it a try and watch volume levels.
