Hello,
Ive just tested my late dads system and it looks like the transformer has failed, is there any schematics on the NAP125 out there
Mike
Hi Mike,
A NAP125!
I suspect this official site will advise you to return the box to Naim.
Mike, I would get in touch with Chris Murphy - he’s based in Wellington and the NZ Naim distributor. He knows the NAP125 very well and has probably worked on most of them in the past.
The 125 was a New Zealand special, back in the chrome bumper days.
Hi, thanks for info.
I have checked transformer and its ok so now im looking at the bridge rec and caps.
The pre amp is nac225 and the speakers are lambert audio sub and 2 satellite speakers.
Record player is a linn sondek LP12.
Im hopeing to get it running again so i can rehome it.
