Quick question on NAT 05 XS tuner, there is a diagram in the manual showing the connection to a flat cap.
Can I use a HCDR instead or even a SC? Just curious.
Yes - it’s actually mentioned in the text of the manual even if not shown in the diagram.
However, if that dedicated to FM, I’d be looking for a NAT 01 instead.
Thanks ricsimas,
I have a 02 oliver and 05 XS tuner. Just itchy to try HCDR on 05XS since getting an extra HCDR at a good price.
Which output on HCDR should I use? Thanks
As above. Socket 4.
I used a HC-DR on my NAT05 XS a couple if years before moving to the SC-DR. While the smaller PSU did what it was supposed to, giving PRaT and relief to a rather dry and linear SQ, the larger one gave air, greater nuances and colors, absolutely delicious.
