Due to a software update I’ve had to review my setup. I use Logitech Media Server to stream to my NDX via UPnP.
I have a 24 bit 88.2khz (SACD?) rip of Dark Side of the Moon and although it will play on my Logitech Touch it will not play on the NAIM NDX. The NDX specs indicate that it should.
Thanks. I am sending it as Flac via UPnP. No error is shown. It just does not play. It plays fine to the Touch but that uses the native SlimProto and not UPnP. If the NDX supports it (which I thought it would, otherwise I imagine it’d not be able to play SACDs!) then the issue must be with either UPnP or the new software update (UPnP Bridge plugin for LMS).
I have tried with a Chromecast Audio into the Naim now too, and although this time the file plays, it sounds really weird. I guess the new (Chromecast/UPnP) software bridges are the issue.
The rip is fine. I’ve looked at the tech and also it plays perfectly on the Logitech Touch.
The UPnP server is Logitech Media Centre. It serves up all other birrates I can throw at it (inc 24/192) so I don’t think it’s LMS.
I can’t use wav (and don’t want to due to lack of metadata) as I’m running the NDX wirelessly and the max I can push through it is 24/96… higher than that and I get wireless drop outs (esp if my son is online gaming). BTW. I am fine about this and I can’t run it wired.
I’m now certain it’s the new software bridge updates and am liaising with the developer.
I might try that for fun when the system is sorted… or I might not… I am normally extremely happy with my system and would rather not have that changed!
You can tell LMS to transcode to WAV see if that helps although it will make the file larger than the flac which given your wireless situation may but a bit more strain on it.
