Trying to thresh out a plan, I’ve another point of indecision. I was thinking that a 200 or 250 would be a good addition to the Atom but am now considering using the Atom as a streaming pre into a Supernait 2. The specs show a similar powered amp and it would leave me with more flexibility going forward and more analogue ins. I can’t find any examples of people doing this though. Is there a reason for this? Would it cause complications with the volume controls. I guess there must be something I’m missing? Thanks Matt
You’d be better swapping the Atom for an ND5XS2 if you went the Supernait route. The Atom doesn’t have a fixed line out and is not ideal.
For sure. Ultimately I do want to go to the ND5XS2 and SN2, but this would be a stop gap before that, as I only have a budget for incremental upgrade. Also the Atom does have RCA pre amp outs, so I wondered why you don’t read of people doing this? cheers Matt
There are so many options! You could connect the Atom to the Supernait and there must be a way to just use the SN’s power amp input using a suitable phono to din lead. Given that the Atom and ND5 are not that different price wise it may be easier to sell that and get both new boxes simultaneously.
Thats a good point Hungry. I’ll look into it. your not wrong about options!
SuperUniti?
Naim have said you can do it and treat is a source , but HH knows his stuff so I suspect yes it can be done but not as good as a dedicated streamer.
Having said that I am thinking of getting a UnitiQute2 for internet radio and perhaps as a secondary system at another time.
I have direct experience using a Unitiqute 2 as a streamer only connected to both a 202/HC/200 and later on an 82/SC/250 and it worked very well and is very user friendly.
Having said that it was bettered sonically by a Raspberry Pi connected to a Chord 2Qute but the Pi/Qute was not as user friendly.
My very best advice if your determined to upgrade would be to sell the atom and buy an ND5XS2/SN2 or SN3 if funds allow.
