Naim Nova Over Heating
Been using Nova for 2 years, connected to the Spatial M3TS speakers., Decided to add REL T9i subs on to the amp, as it turns out the Nova begun to over heat after almost 2 hours of continuous use. Its mind boggling as to why the Amp would over heat.
The wiring installation was done by the retailer, in the right manner, using the supplied cables from REL.
Anyone having gone through this experience ,… much appreciate the advice
Hi sudesh, have you unplugged the T9i’s and run for 2 hours continuous just to see if it is the addition of the subs causing the issue? might be a good place to start.
