System is 272 / CHC555 through to a 300DR. Use 2 Powerline Lites at the moment.
Got myself a Powerline. Am I right in assuming that I’m best to connect the CHC555 rather than the 300PS?
Gordon
So easy to try it on both and see which one you prefer
Mine is similar kit but a Naim 555PS instead of the CHC equivalent. Using the PL on the 555 made a bigger difference than adding one to the 300PS. I found a good deal so now have two, one to each box. I’d go for the 555 but it’s a trivial thing to switch over and compare. Get used to one before swapping - give it a week or two then rotate.
