I got a 4-pin din to 2 phono (l/r), thence to Canford unbal-balanced transformers, then XLR’s from my Supercap to ATC SCM40A’s giving a proper balanced output from the unbalanced Supercap.
Is that from a Nac-282 to 1 or 2 of these Canford transformers? What is the price-point for these?
Does this methodology reduce the output available from the mono amps? It has been suggested to me that RCA connectors reduce the output signal from the pre-amp.
I can’t help you with RMS/V output via the Canfords, but suspect that, in conjunction with my 'speakers has made the volume much more controllable from the 6:35 to 9 o’clock positions compared with my old speakers and NAP 135’s.
I am using the transformers as I am using equal length 5metre XLR cables. I believe some on the forum use XLR’s without transformers.
Price-wise, the transformers were c£216/pair excluding any cables.
One thing to keep in mind, is can the chord amp be run from a pseudo balanced input. At least with the other solution, you would have a fully balanced signal from the unbal - balanced transformer.
Correct but it will work to connect a Naim Preamp to an amp with balanced XLR inputs. It’s not like the cable to connect to the 300DR which won’t work with balanced XLR’s
