I have a pair of SBLs that I have owned for many years. Should I get the crossovers serviced or should I leave them alone?
I can only say that I did get mine serviced and the result was better - smoother, and especially noticeable on the upper frequencies which had become harsh/edgy.
Ok I will go for it. Thanks
I vaguely remember there being a X-over assembly upgrade available.
Most noticeable was the electrolytic capacitors replaced with plastic film types.
