Up for service will be my nap250 555ps and supercap obviously I’ll do one at a time what would be the first ? All around the 10year mark
Where are you?
Martin
Of those the most critical would be the NAP250 as it’s a fully regulated power amp, so when things start to go off spec then the knock on effects can be quite marked compared to a normal unregulated power amp.
If you are located in the UK then you have the choice of either going through your local Naim dealer for a factory service (and factory service history) or else using the approved Naim servicer Class A, which may also work out to be more affordable.
Thanks Richard spot on
Fife Scotland
Black box “classics” have a recommended 12 to 15 year service interval, so no immediate rush, and you can space them out a bit.
Good to know, cheers
Martin
