Hello,
I own a combo of Nac72, Nap 140 and Hicap.
This combo was out of service for a year.
Everything was stored safely.
When it was put back into service, suddenly the snaic 4 pin was
was defective. How can this happen and is there a way to repair the cable.
Thanks for your efforts
Markus
Are you certain it’s the SNAIC? Have you done a continuity test on it?
Have you tested with just the NAC72 and NAP140 (you’ll need to refit the link plug) as well as with the HICAP between the NAC72 and NAP140?
