Colour me crazy but why are the connections from my Snaxos 3-6 Olive are done like this? You would think that for each active system the Nap 250’s would take care of Bass(right and left) off one amp, the mid range on the next 250 and the third amp for the tweeters. The tweeters amp is right and left speaker but the bass and midrange come of of each amp as in the picture. also would I be right in assuming the top three outputs are for the NBL’s and the second row is for DBL’s?
Because you want the Nap 250’s to have one channel /transformer like in monoblocks ( Nap 135),for better separation and to make it easier for the amps.
The early Snaxos were wired like this. They changed at some point - I think when Classic was introduced - to the more standard one for bass, one for mid, one for treble.
Yes, the orientation was changed with the introduction of the SNAXO 242 and SNAXO 362. The advantage is that you don’t need close matching of the amps, and indeed you can even mix different models.
With older NAXOs and SNAXOs you need to be careful as they were sometimes re-wired internally so owners could use them with dissimilar amplifiers…
That’s what I assumed also. I’ve had issues with getting the system to sound right. Been playing with them for a year now. I had SBL’s before with a two way active and it blew away the sound of these. I changed connections as in the diagram and it’s like a whole new sound. I put it to the test when I return home.
As my long term project is to “activated” the DBL with a sixerpack 350 without exploding them because one pair is soon quite enough to dynamite them, I find recently a Snaxo 3-6.
This filter was at the beginning prepared for DBL but was transforming for Isobarik by Naim so the seller says to me.
So I hope Naim could transform it again and make the reverse operation.
After that I will try to find a Supercap olive with a H-F transformer in the best case.
But I have here a question: shall I have to use between the 350 and the Snaxo, the new and same cables I use yet between the PS and the 350?
I don’t think that’s possible,the Supercap was introduced in -95 after H-F transformers…
and when I upgraded an older 52PS to Supercap,the transformer was changed to a new one.
