Naim Solstice Tonearm balancing issues
Hello
I have an issue with the Solstice tonearm.
From the start when i bough the item in 2021 i was not able to align the arm with the two vertical lines marked by Naim only as it shows in the attached photo.
In 2026 , roughly 2 months ago, i have taken the Solstice apart and moved it to another city and when trying to put it up again the tonearm could not be balanced at all.
After going back and forward with Naim service in Poland about the situation the following have been tested and tried by a professional (not myself) :
Verify the turntable chassis and platter are perfectly level using the supplied bubble level.
Confirm the tonearm is installed with the alignment marks correctly matched and that the arm pillar is seated correctly in the collar.
Set anti-skate to minimum/off and attempt to achieve neutral arm balance.
Check that the tonearm wiring below the arm pillar is not twisted, trapped or under tension.
Re-establish tracking force using the supplied digital stylus gauge. Naim recommends an Equinox tracking force between 2.2 g and 2.4 g.
Verify cartridge azimuth and VTA using the supplied spirit level in accordance with the setup procedure described in the Solstice User Guide attached.
Unfortunately Naim UK cannot take the tonearm into service and this is their official response:
At present, based on the information available, we do not believe the turntable chassis, platter bearing or power supply are implicated in the fault. The issue appears localised to the ARO tonearm assembly and/or its internal wiring.
Following a review of the fault description and the information provided, our Service Department has confirmed that we are unable to offer either an inspection or repair for this tonearm. Based on the information available and the symptoms described, the issue does not appear to be attributable to a product defect. Unfortunately, the condition reported cannot be remedied through our service programme.
In addition, as the Solstice Special Edition was a limited-production product, the service stock of replacement ARO tonearms and associated spare assemblies has now been fully depleted. Regrettably, this means we are also unable to supply a replacement tonearm.
Is there a repair shop in Europe where i can send the item for inspection and/or repair that is specialized in tonearms ?
I can also provide a short video with the arm’s issue.
Much appreciated !
Hi GTV, sorry to hear of your issue. I guess the first question is when you first noticed an issue aligning the two lines 5 years ago, did you notify your dealer and was the unit replaced then? i.e. Are we talking about the same issue with the replacement, or is this the same issue and same unit as original?
I don’t know a great deal about setting up the Solstice and ARO2 but I do know a man who does, so on Monday I will ask him to take a look at this thread and see whether there’s anything he can advise.
FWIW, it was made for Naim by Clearaudio, so while it sounds like Naim themselves can no longer supply any replacement ARO2s, Clearaudio may be able to advise regarding service within the EU.
No i did not contact the dealer as i didn’t take the two stickers with the marker too seriously and mainly because it worked fine at the requested parameters after i set it up. And it sit in the same place without being moved for 5 years.
The issue started when i took it apart i felt something moving or rather sliding up mainly from what i could tell the two base cylinders as per the red markings. The arm was not opened or tempered with as far i m aware and the internal wiring seems to be working as there is a hum coming from the cartridge when cold tested. I’m personally assuming now that i got a misaligned arm in the first place and the mistake of not contacting the dealer about it in the beginning coupled with me taking it apart for the second time made things worse.
I would greatly appreciate the help and if you need more info i m happy to provide it!
Im sorry to hear of your troubles and that the arm is not usable. I’ve essentially set mine up twice and things always lined up and the arm behaved. If the markings NEVER lined up properly, it may well have been a hardware fault right out of the box. The only other option would have been ‘user error’ when setting it up, but the set up is quite straight-forward (even I could do it) and unless you really banged it around, which I’m sure is not the case, something probably was wrong from the factory :frowning:
The “problem” now is that so much time has passed . . . long out of warranty. But it sounds like Naim would have tried to do SOMETHING for you, but with no replacements in stock they have no real options. The only option might be to find a tonearm genius who maybe could sort it out just going on instinct. Maybe a dealer in the UK who sold and set up several ‘back in the day?’ But despite the significant initial investment, you could quickly accrue even more costs to get that work done.
Im sorry I don’t have any solution, just some sympathy!
Hi GTV, sorry to hear this. For a specialist repair in Europe, a few names that focus exactly on this: The HiFi Gallery in Scotland explicitly offers tonearm repairs and calls Linn Ittoks and Naim Aros their speciality, and their repair page says the service follows training by John Nielson of Audio Origami. Audio Origami themselves are long-standing tonearm specialists and do rewires and repairs. Deco Audio also offers tonearm rebuilds back to factory specification. Since your issue sounds like it may sit in the arm pillar or its internal wiring, I would describe the symptoms by email and ask for an assessment before shipping - that is a guess on my part though, not a diagnosis. Hope you get the arm sorted.
Naim has an option : take the arm in and see if it requires calibration or repair. No one spoke about spare parts and mechanical repairs. I had a bad feeling about me receiving a defective unit when i have forwarded Naim the SN from the product: usually their response time was 5-7 days, after they got the SN from my Solstice i got the answer in 2 hours or less. For a company that prides itself for repairing and upgrading 20 years old products they were pretty swift to throw me under the buss with a generic “sorry we cannot offer any form of support . ty /bye “ . But then agian this post is not about me complaining about Naim poor PR but about fixing the problem.
