Naim Speaker Connectors Query
Just to clarify if the Naim angled speaker connectors will fit into a NAP 140 ?
If you mean the Naim SA8 speaker connector then yes, they will fit a NAP140.
How are they superior to standard 4mm plugs ?
They are the same metal to metal match for the sockets, require good quality soldering (a good thing) and the case allows the pins a small amount of movement so they can follow the best path down the socket, while also ensuring that any torsional strain is minimised, which at best can give a less than optimum internal contact area, and at worst can cause PCB damage where 4mm sockets are PCB mounted.
There are at least two different width spacing for Naim speaker connectors which I found see attached link
The right angled plugs all have the standard 19mm spacing which the OP needs. Only the straight plugs supplied with the Atom, Unitiqute and NAP100 are different.
